Spraying Awlgrip ?
Gelmaster
7 Oct 2010
Ynysybwl, wales
Ime thinking about spraying a GRP..Gel surface 32 footer using Awlgrip!
Will only be spraying from rubbing strip to waterline.
I am already proficient in the art of spraying.
Any advice on orange peel prevention other than ....
correct thinning & checking the water trap regular??
I bet there are a thousand reasons out there somewhere!
I know minimal orange peel is the norm...to be flatted back, but want to try and get it right first time!
Any tips and suggestions at all , very welcome!!
Never used Awlgrip before...so much choice available, i have the uk dealers contact info "Southampton", but was just wondering how good it is to work with!
You will need to clean the hull thoroughly to remove all wax and silicone, not an easy job.
The surface of grp is actually porous with small voids so causes peoblems ask AWlgrip.
You can actually get a very good brush on finish using Int perfection in the right conditions.
