savageseadog
Following a collision at the weekend I have been informed by the surveyor that his recommendation to the insurers will be that the hull is re-sprayed all round (white) rather than risk mismatching gel coats in a few months when they start to fade at different rates. This is in part because they cannot get the same gel coat as used in construction so it will be a mix with a totally different pigmented resin. The hull is damaged is several locations down the starboard side.
The original gel coat is in excellent condition (pearly shiny white) and i am not keen to have it re-sprayed. As i can see it all rubbing off on the fenders in the marina (like oh so many other boats i see around)
Any one any thoughts and advice. Does a spray job reduce the resale value of a boat? or is a new two-pack spray job going to be much better than a patchy hull in the long term?
