aevans692
Hi all ..
We have been using the spinnaker a lot more when we go out , ours came with a snuffer , now I see the benefits of this , but I have found that sometime it manages to get twisted inside the sock , and sometimes the snuffer doesn't raise all the way to the top, leaving the sail still inside, about a meter or so from the top no matter what I do the snuffer just doesn't have enough room to go all the way up , because of the gather from the snuffer ..?
Is this normal with using a snuffer , because atm I'm in two minds and Im thinking about taking it off ..
Im guessing if I take it off I will obviously have a full sail out rather than a shorter sail caused be the constraints of the snuffer .. But i can pull the sail down quick should I need to ??
What are all your thoughts .. Cheers Andy .
