john_morris_uk
This is a bit of how longs a piece of string but here goes.
I need one (or maybe two) new spinnaker poles for Serendipity. The J is 4880mm so these are not small.
I've had quotes for a single pole that vary between £2k and just under £300! These are for new poles from mainstream suppliers.
The variation seems to be in diameter of the pole. One has said a 96mm diameter pole would be the best but I might get away with a 80mm diameter pole. The £2k one said definitely 100mm and another main factory outlet said 80mm will be fine. (The latter being also the cheapest!)
I can have two poles and an extra car for the track on the mast for £600 if I go cheapest. I'm well aware that cheapest isn't always the best and you can buy cheap and buy again when the first ones break! The same supplier will provide two 100mm poles plus a car for about £1500.
I will need to add another spinnaker pole topping lift to the rig. (More slots in the mast...)
We don't get the spinnaker (or as Mrs M calls it, "The Bag of Fright") out when cruising two up as a kite that's 54' on the luffs is quite large for me to manage with Mrs M. However we do want to make provision for twin pole sailing downwind in the trades. Two genoas poled out wing on wing is my preferred option for trade wind sailing. The poles need to be man enough for this sort of work.
Any ideas or suggestions or opinions?
