Spindrift hits a RIB and MOD 70 Virbec Paprec capsizes
Allan
17 Mar 2004
Lymington
Spindrift always has one hull "flying". She is designed to have the central hull and one side hull in the water and the other " flying".
Allan
bbg
2 May 2005
Okay, I have never sailed a multihull let alone a racing one.
BUT it all happened rather slowly as she started to fly a hull. So why didn't they dump the main as soon as the hull started to lift?
At the end of the video they said there is a button for the driver to blow the main sheet (it is hydraulic) but for some reason it didn't work. It wasn't clear whether he didn't punch the button or whether it just didn't work. During the video you can see the driver fall into the water, so maybe he had already lost the position to punch the button?
I thought the initial lift happened quickly and they probably got to the point of no return in a couple of seconds.
Sybarite
7 Dec 2002
France
As far as the Spindrift accident is concerned, theoretically the driver must be able to manouvre his boat in all circumstances. It is not a defense to say that they require a lot of room and that other boats should stay clear even if they have right of way.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Flying the windward hull on trimarans is intentional and part of the design. The beams usually make a shallow V shape. All Farriers and Dragonflies do it. It's flying the main hull that is risky and pushing it too far.
Tomahawk
5 Sep 2010
Where life is good
The lift from comfortable to critical took only about 1/4 of a second... Why the helm didn't dump is a mistery.
Though he probably took a dump shortly after...:disgust:
Lakesailor
15 Feb 2005
Near Here
I didn't get my central hull to lift..................
