PaulRainbow
This particular boat was built in Holland in 1999 to a high standard, with Mastervolt switch panels, mains charger, alternator with external regulator, inverter etc. The electrical system is documented and has a schematic showing fuses etc.
Last Friday the new owner called me to say that shortly after turning the kettle on (using the inverter) the kettle stopped boiling and there was no output from the inverter. I got him to follow the inverter cables and he found the fuse, which was clearly blown ( he sent me a pic). Noting that it was a 160A fuse and knowing that the boat had a 2500W inverter, i told the owner that the fuse was under rated, it should be a 300A fuse for a 2500W inverter. He cited the schematic and told me that is showed a 16A fuse and that was the original schematic from when the boat was built. I insisted that the fuse was wrong, it should be 300A, if the system was 24V a 160A fuse would have been correct.
He reminded me the boat was all 12V (i knew this) but as he did so, he noticed the detail, top right, which i've circled in red. So, built using 12V systems and a 24V design schematic, all of the fuses greatly under rated, except one. In the 22 years since the boat was built i wonder how many times that inverter fuse has blown ?
All fuses now replaced with the correct ones and everything is working exactly as it should, only took 22 years to get there ?
