Thepipdoc
.... Mid English Channel the engine bay bilge alarm sounded and it's not a noise you want to hear while you're 35 miles from land!
After some investigation I discovered that the boat was bone dry on the inside and the noise was caused by a knackered float switch and the only way I could "shut it up" was to cut the feed to it which wasn't easy given that it was buried deep in the recess of the bilge.
The photo below shows the hole that was burnt into the casing of the switch.
