Spark Plugs-advice please
DAKA
7 Jan 2005
Nomadic
My Tohatsu 9.8 hp two stroke outboard was playing up and running rough at slow speeds , I bought a couple of spark plugs that looked about the right size and put one in the pot that was showing a wet plug.
The results were immediate and I am back to full speed.
The old plug was BP R 7HS-10
The new plugs are BP 7HS-10
The R stands for resistor , my original plugs had a resistor in and the new one doesn't include a resistor.
What is a resistor .
Before I cause any damage do I need to buy two new plugs with a resistor in ?
Thanks Paul, they are the same plugs (NGK)then thats good news as the tender does not have plotter/radar etc.
Out of interest I will try the hand held GPS .
Cheers
Thanks Kawaski,
The gap I need is 1mm, which is bigger than my feeler gauges*, I used a ruler to measure and guessed these come pre gapped to 1mm , just checked and that isnt 25 1oooths its .6 I think
Sorry, yep 40 thou!
Can't think in metric
Blimey I,ve only just got used to decimal coinage peeps!
Anyway just so's yer know (and others)they have a bigger gap than 'standard'!
The hyphen number tagged onto the end of some NGK plugs indicates that they are supplied ready gapped to that number in tenths of a mm. so 10 as said means it is supplied ready set at 1 mm. If that is not the required gap then it has to be adjusted!
There are other preset gaps from 8 = 0.8mm to 15 = 1.5 mm. 10 is the only one I have come across though.
No number means a standard gap ... dunno what that is though!
