Spare Air Emergency Dive System
mattnj
26 Jul 2007
www.red-data.co.uk
Spare Air Cylinder with built in regulator, perfect to keep onboard should you need to go in and clear a fouled prop, gives you around 3-4 minutes underwater, comes with the original box and filling A-Clamp, good working order as it should be.
We used it for the occasional barnicle removal and general checkup underneath, no longer needed.
£100 posted to you.
mattnj
26 Jul 2007
www.red-data.co.uk
It doesnt need a test as it is under 1 litre, I just filled it from a dive cylinder, i did take it into a dive shop last week and the chap took the regulator off the top and looked inside with a torch and said all looked good (no corrosion) and that it was fine.
You can get it tested if you want for peace of mind, the original test stamped on the cylinder has expired.
