southerly plumbing
PTB
14 Mar 2005
bromsgrove, worcs
Boat 200 miles away and need to order a few bits! ... Anyone know off the top of head what domestic water plumbing system northshore used on the 110 .... I am guessing Hep2o 15mm ??? Thanks P
Whilst it is not recommended (by the makers anyway) to mix them, plastic 15mm is plastic 15mm OD regardeless of origin and though I only use JG Speedfit I often have to connect to other systems and to date have never had a problem. So you could almost certainly use any decent quality fittings, one caveat is that though the OD is 15mm the bores can differ slightly between makers so the inserts can be an issue. It is unlikely that it will be anything other than 15mm, some US and Far-Eastern boats are 1/2" but that shouldn't concern you on your boat.
Old style 15 mm demountable Hep fittings used on mine. Boat is no 8 - 2000 vintage. Pipe work although compatible with Hep seems otherwise though.
