vas
Hello again,
boat will be moved out tomorrow so my last chances to check things.
Genny felt a bit too noisy to me, so downloaded soundmeter on my android mobile, setup the profile for my phone and did some tests.
Boat in the marina, not exceptionally tranquil as it's 30 or so metres from a street that is not too busy, but there are cars passing regularly (as in one very 5-10secs)
Anyway, phone on the helm on a solid surface vinyl lined so softish no reverb. Closed the salon door and did the following tests:
Engines off : 38-40db
both engines on idle: 80db
engoff genny on : 70db
Genny is aft of the stbrd engine so under the salon floor.
Genny is an oldish MASE green something like 4-5kva, proper marine thing, with all the pipework in place a silencer (me thinks) and gasses/water exit at the stbrd engine exhaust grp tunnel at the transom.
Called my mate with the P410 5 boats down the pontoon (his is a very quiet genny), heard it and freaked out. Suggested I move the genny aft in the lazerrete (sp?) and scrap my one water tank taking the place there (or move it fwd a bit) Also recommends to do a decent isolation box for it once in place.
Don't mind the shifting things about too much, I honestly think that if the genny stays where it is, will be only used for the espressos and the watermaker (unless I get a 24V one...) I doubt anyone will agree to use it for the aircon either...
Any views?
cheers
V.
Any views?
cheers
V.
