Forfatsnakes
New Member
Can anyone tell me why I have soot coming out of my ysm8 exhaust? It runs ok for an underpowered engine ! But I leave a residue of soot on the water as I go , not oil , anyone know what could be the cause please ?
Its only a 4kw engine, if it is overloaded it will produce black carbon smoke and hence soot. If the injector is not atomising properly it will also smoke.Can anyone tell me why I have soot coming out of my ysm8 exhaust? It runs ok for an underpowered engine ! But I leave a residue of soot on the water as I go , not oil , anyone know what could be the cause please ?
I will check the exhaust elbow tomorrow, I only have a small 2 blade prop on her , I will try anything , it's embarrassing, even ticking over .It may be that your engine is over-propped and is generating black smoke that is being 'washed' by the cooling water. You say it's under-powered, maybe the prop is not the correct size to allow it to get to full RPM. As dankilb says above - a blocked up exhaust elbow might also give those symptoms.
Thanks for that , I will certainly check all those .First look for build up of weed or barnacles on the prop or bottom of the boat. Also check theres no tightness in the shaft line.
If that's ok then, Try some liquid moly diesel purge on the injector.
Exhaust elbows are always worth a periodic check with or without symptoms.
Occasionally wet exhaust hose has been known to fail internally and produce similar symptoms to a blocked elbow.
This does sound more suspicious than just ‘blowing coal’ under heavy load (as the diesel car tuner/truck pull lot call it!)even ticking over
