cmedsailor
In the past I had lots of vibrations especially in high rpm. During the period the boat was out of the water I did the following:
- Changed the vetus front engine mounts with the Volvo ones (the vetus were relatively new and in great condition but since I had two brand new Volvo ones I bought in the past by mistake it cost nothing to replace them).
- Changed the cutlass bearing (the typical rubber style you find in lots of Beneteau) which was in a very bad condition and definitely causing vibrations
- Removed the shaft and checked that was perfectly straight
- Aligned the shaft – engine.
- Replaced the 2-blade prop with a 3-blade (2 blades behind the skeg could also be a reason for vibrations)
The boat is back in the water and things are much better. However I do get some vibrations at around 1100-1300rpm, less vibrations at idle (800-900rpm) and no vibrations above 1500rpm (even at 3000rpm). The engine is a volvo penta MD2030D.
Do you think these vibrations are now a matter of some fine tuning of the alignment, or does the current situation sounds normal? I know that many engines do have some specific rpm that “shake a little bit”. I cannot decide if it’s worth messing with the alignment again.
