I’ve always been amazed by the number of visitors to Lakka who just drop the anchor to the sea bed without ensuring that their anchor is dug in, and then go ashore. The holding there is very good because the sand is firm. However that means that the anchor usually takes a bit of encouragement to start burying. I’ve seen similar chaos there on several occasions. If I’ve ever seen a boat near me not bothering to set their anchor I’ve usually dived to have a look, for peace of mind. Invariably I’ve found anchors just sitting on the surface of the sand, ready to slide along at the slightest provocation. Fortunately a bit of a waggle on the anchor’s shank has usually been enough to start the pointy end burying.
I’ve often anchored and taken lines ashore on the starboard side as you enter the bay. I had a catamaran then which only drew 1.1 meters so I could go fairly close to the rocks. As long as the bow anchor is biting into the sand it’s a bombproof anchorage because the rocks aren’t going to move. The water is usually very clear there so it’s not essential to dive on the anchor.It seemed to me that the main ones in trouble were lying on long lines to shore and not free anchoring - but even they were holding but very scarily laid over.
Seen you having a interesting time in Greece this year .Two massive fronts just passed over Vonitsa. We re-anchored from the crowded anchorage behind the bridge and dodged a bullet. According to our friends who stayed, two boats dragged through where we had been and lightning struck the water there ?
