Soldering Iron Tip Cleaners - SS vs Brass Wire Balls?
Skylark
4 Jun 2007
Home: North West, Boat: The Clyde
A bit boaty........
First question, are soldering iron tip cleaner / wire balls good if there's a fair amount of work to be done?
Any significant difference / pros and cons of stainless versus brass wire balls?
Grateful to receive hands-on experience?
Many thanks
The stainless ones tend not to attract solder.
Generally, if 'there's a fair amount of work to be done ', I'd suggest getting a new tip.
It depends on what atrocity your iron has been subected to.
The tip cleaners which are little tins with a 'cake' of flux and solder in are quite useful sometimes.
Another thing that works is to coat the cold tip with flux and let it heat up. A fairly mild electronics type flux wouldbe my first choice, you can get it in a marker pen. Then tin with cored solder as the iron heats up.
Unfortunetely the higher temperatures with lead-free solder give tips a very hard time. Don't leave the iron hot for hours if you can avoid it.
I occasionally clean mine with a stanley knife blade and when very bad with a file when cold. I also use cotton rag to give it a quick wipe.
Not to sure whether this is correct but it was how I was told to do it at an electronics company where I worked during college holidays.
Scraping or filing a tip is strictly for when you're desparate.
Soldering tips generally have a copper core with a coating of some other metal, often Iron.
Once the Iron coating is gone, the solder starts to dissolve the copper.
No, this stuff...
Lead-Free Soldering Iron Tip Refresher Solder Cleaner, for weller, metcal etc | eBay
The wire or wet sponge ones are ok as you go along, but once a day this stuff really improves the tip & instantly makes it completely tinned.
That stuff looks really useful, thanks for the link.
I did not know those wire tips were composite, well well. This chap has an interesting solution to claggy tips:
Soldering Iron Tips From 6 AWG Copper Wire
BTW. I have a medium weight Weller iron that has never been plugged in, I heat it on the stove and it works very well on the boat in the absence of mains power.
