[10753]
I have a 12v 913 Wind Generator which runs constantly through a Rutland HRDI Regulator which looks after my 3 batteries.
Due to to additional useage of power when onboard (most weekends and 4 weeks) I am considering adding either a 60w or 80w SOLAR panel which will also go through the HRDI controller.
Question is that when I leave the boat should I
a) not do anything knowing that the WG and SOLAR will be producing loads of unwanted power - can that damage anything ?
b) Put a switch on the SOLAR panel so I can turn it off (if that is possible and should it switch both +ive and -ive off?)
c) Cover the SOLAR panel
Final Question - Marlec say 'Input for up to 160Watts of solar panels. Note : in ambient temperatures >40°C the solar panel
input must be de-rated. Contact your dealer or the manufacturer for advice' What does de-rated mean ? and is this panel ok ?
http://www.sunstore.co.uk/12v-80w-Monocrystalline-Solar-Panel.html
thank you for your tips
