Ludd
Please can someone with more elecrical knowledge than I advise me?
I have a Duogen wind/water generator with it's own regulator,feeding a bank of 5x110 Ah batteries
Wired into the same regulator I have two 80watt solar panels: so far so good,the system works well.
I want to add 2x90 watt panels. I can't put them through the Duogen regulator,as it is already up to it's limit.
Can I run the two extra panels through an independent MPPT controller,or even run all four panels through one MPPT controller,independent of the Duogen? What amperage MPPT controller would I need to use
1) to run 2x90watts panels
2)to run all four,e.g,2x90 watt+2x80watt panels.?
