jonathankent
I'm having trouble with my solar panels... some help would be much appreciated (I have read the chapter in Nigel's Mech & Elec Manual, yet am still 'in the dark').
I have got 2 panels, 35cm x 45cm so not too small, one 75aH battery, and have just bought a regulator. The panels don't seem to be charging the battery - the voltage is actually decreasing!! I don't know the exact watts of the panels (the text on the reverse has faded) but can make out some values for quote "1000 w m-2" and "800 w m-2" and "13.7 watts", but this seems quite low to me. I am assuming 1000 w m-2 means 1000 watts per square meter (the 2 panels have a total of 0.32 sq m). The other morning, fairly sunny, I had approx 12 volts across the panels (open circuit not connected to anything), but shouldn't I be getting more - the book suggests 16-20v. My main concern is the amps being produced. I can make out on the reverse a 1.5a and a 0.92a, but this doesn't seem to relate to anything, well not that I can work out anyway. I have checked with a multimeter and was only getting 1.6 (which was using a 0-200mA scale) but surely 2 panels of this size with 12 volts would be producing far more than 1.6mA - the regulator uses 4mA!! - could explain why battery voltage is dropping, but not at the rate of 1volt in 3hrs.
Any suggestions would be much appreciated.
P.S. I have checked voltages at each stage through the wiring and all seems to "add up".
