Hi,
I suspect that the regulator for my solar panels is in the process of failing and I'm looking for a replacement. The ones I have found dump excess power into a dummy load of some description, generating a fair bit of heat. I thought you could just open the circuit on solar panels without causing any damage. If this is tru can anyone recommend a regulator that will do this?
Regards
Fred
Just because you're paranoid doesn't mean they aren't out to get you.
Regards
Fred
