Solar Panel going cloudy
Trundlebug
4 Jan 2007
River Trent
I fitted a 150w semi flexible solar panel a couple of years ago.
On visiting the boat at the weekend I decided to clean the topsides after the winter, ready for relaunching and I noticed the outer plastic film of the solar panel appears to be going milky / cloudy.
After only two years it's looking quite weathered and old.
Has anyone else had this problem?
Does it affect performance?
How much worse will it get?
Any thoughts appreciated.
r_h
5 Jun 2006
West coast France, Solent + E. Med
www.rupertholmes.co.uk
Sounds like one I have that's three years old now. It appears to be a very thin plastic film that's breaking down. A bit of a pain but no big deal - I'm waiting for it to break down a bit more in the hope that it mean it won't take as long to remove it all and get back to a nice clear finish.
Trundlebug
4 Jan 2007
River Trent
Remove it? That will expose the bare solar cells to the elements which I don't think will do them any good.
Trundlebug
4 Jan 2007
River Trent
The very thin film present on delivery is just to protect it during transport.
It's packaging, rather like the film wrapping on cars and boats during transport, and is a common feature on many plastic covered items (even phones) with easily scratched surfaces.
I removed that film straight after installation. Leaving the main residual plastic coating on the semi flexible solar panel.
It's that plastic that is now going cloudy.
I may try some special polishes, but I have a feeling it's the plastic itself going cloudy rather than the surface. Worth a try though I suppose.
Trundlebug
4 Jan 2007
River Trent
Not quite sure what you're asking Fergie_mac.
When new my panel had an anti scratch coating on, yes.
I removed it (like you do with a smart phone) when I installed it to leave the solar panel, which has a clear plastic outer layer. That layer is not removable.
The clear plastic outer layer of the solar panel has gone cloudy.
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
Be VERY careful polishing semi-flexible panels. Personally, I would not touch that with a 10-foot pole.
The problems is that the cells themselves are rigid and very fragile. If flexed back and forth--and they will be when you rub--they will develop micro-cracks you can't even see, and the output will drop by FAR more than is caused by a little surface oxidation. Google it, and you will read many stories of woe, where a sailor polished a panel and was then surprised that output had dropped 70%. This is also the reason that semi-flexible panels don't last when installed across a bimini bow. At most, clean gently and apply a plastic protectant, like 303 or IMAR.
Don't take the risk. It isn't worth it. The cheaper the panel, the greater the risk.
