Ronald_M
Hi all.
My boat's electrical system is modest: A single 85 amp/hr battery, connected, via a 16amp fuse and an isolator, to a small switch panel. This panel has a number of individually fused and switched outputs. From here I can select cabin lights, nav lights, log & depth or a couple of 12v "cigar-lighter" sockets for powering accessories. Battery charging will be provided by either the 3amp(max) rectified output from my Honda outboard's "lighting coil", or by a small 7 watt solar-panel. As this panel is so small, it is not necessary to regulate its output.
My question is how best to connect these two charging sources. Is it appropriate to fit each with a (fused) 12v "cigar-lighter" plug and charge the battery via the corresponding socket, or is it more effective/better practice to connect them to a point nearer to the battery, ie immediately "downstream" of the battery's main fuse?
All suggestions will be gratefully received!
Ron.
Ron.
