mitiempo
Only if the panel is infinitely large, or attached to an effectively infinite resistance - neither of which really apply. If you connect a 50W panel across a 1ohm resistor you will not get 50W dissipated in the resistor however bright the sunlight
A panel of a given size with too small a wire will give less output where it counts if wire too small is used. It is not much different than a large flow of water through a small tube - it is a restriction.
Why would anyone pay for a good solar panel and then restrict its output by saving a few dollars on the wire?
