DaveRo
I have a 1-year old SO35. There appears to be a partial blockage in the water supply from the aft tank to the taps which control which tank is feeding the filter and pump. The symptoms are that the flow reduces to a trickle and the pump takes a long time to repressurise the system after a tap is turned off. If I turn on the forward tank the water flows freely and the pump stops.
I had this problem last year and it cleared itself. My guess is that there's some dirt or plastic swarf in the tank which blocks the outlet. It could also be an air-lock in the pipe. Removing the filler cap doesn't help - so not a breather problem.
There's probably a strainer in the system somewhere and maybe some non-return valves (?) but the owner's manual gives no clues.
Any SO35 owners with this problem or ideas on how to clear it without taking everything apart? Where are the strainer(s)? Is there a non-return valve anywhere?
I could just leave it to clear itself but I'm afraid that the pump might be damaged. How about backwashing the pipework with a hose - is that likely to damage anything?
