Smoke detector alarms problem.
graham
I thought this report on the CHIRP website maybe of interest.As it highlights a problem that is not normally considered.
SMOKE ALARMS
Report Text: Smoke alarms can damage your safety. Whilst motoring in calm weather in a 10m motor sailor with the wheelhouse doors closed, suddenly (within 5 seconds) the whole yacht filled with acrid smoke, such that it was not possible to see from the wheelhouse through to the fore cabin, some 5m. There was no indication of the source and no flames visible. The engine was stopped, an engine fault being the immediate thought even though there was no change in engine noise; then it was realised that for the whole boat to fill with smoke so quickly it must have been dispersed through the (diesel-fired) blown air heater. The heater locker was opened gingerly, with a fire extinguisher at the ready, but there were no signs of smoke or flames. It was later found that the diesel cut-off solenoid had shorted, the heat generated being enough to vaporise the solenoid packing and the resultant thick smoke was sucked into the intake and dispersed round the boat. The intake is deliberately from that locker in order to provide forced circulation of air. So far, so good: the unexpected problem was the smoke alarms. There are three, one in each cabin (each can be closed off): all three sounded within seconds of the smoke appearing. <span style="color:red"> The problem was that the resulting noise made it difficult to think clearly and would have made it completely impossible for the Coastguard to have distinguished the words of any transmission, or for me to have heard their reply.[/color red] I could have taken the microphone outside the wheelhouse, but would still have been unable to hear their reply. The alarms are the common domestic type: it would be possible to fit a switch in the wheelhouse controlling them, but this would be complex and give scope for failure. There seems no easy answer to this problem and it is perhaps one which does not occur to most yachtsmen: it didn't occur to me until it happened.
CHIRP Comment: A number of accident investigations have established beyond doubt that smoke alarms can save lives. In this incident the alarms did exactly what they are supposed to do and provided prompt warning of a problem and had the crew been asleep, for example, this warning could have been a life saver.
The report does highlight the need to consider what is the best smoke detection system for your needs, where sensors should be located and what impact they might have on communication should they be activated. It is always a good idea to have a plan for the worst, whilst hoping for the best. <font class="small">Code:</font><hr /><pre> </pre><hr /> <font class="small">Code:</font><hr /><pre> </pre><hr />
We have a smoke alarm that goes off every time SWMBO makes toast. It has a bayonet fixing so it can quickly be removed from its base then we just wave it out if the window till it stops.
I agree that once the alarm has got your attention you want it silenced so you can think/act. On the other hand any sort of on/off switch could inadvertently be left in the 'off' position which would be dangerous.
Get one of the types intended for use in caravans. Because the kitchen is part of the living space (as in a boat) the alarm is likely to operate whenever the stove is in use. So it is fitted with a 'hush button', which reduces the detector's sensitivity for a few minutes. This means that the detector operates, the button is pushed, and the alarm stops for long enough to pass a message. And it reduces the annoyance from burnt toast.
Remember, though, that if the fire is still burning then the last place you want to be is down in the cabin. Either have a deck-mounted control for the VHF, or have a hand-held. And <u>don't</u> keep your flares down in the cabin!
