'smart' regulator and electrical interference
gtuson
14 Feb 2002
Me and boat Llangwm, Pembrokehire
\'smart\' regulator and electrical interference
I fittted a Sterling smart regulator and it seems to be interering with oil pressure guage - needle flickers wildly in time with particualr stage of charging + sometimes needle goes right over to maximum...Any ideas on how to cure this?
Re: \'smart\' regulator and electrical interference
Had the same problen, check to see if the equilising diode flickers with all batterys charging, if so, connect the Two earth wires directly on the alternator frame, seperate from any other earthing points, especially it its a Lucas alt, cured my fault.
Your problem is not interference, it is fluctuating voltage as a result of the smart regulator doing its job. To overcome this completely you need to fit a voltage stabiliser in the feed to your instruments.
These can be obtained from a car breakers.
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
