Small/thin washing machine
Whitelighter
4 Apr 2005
Looking out of the window
id like to try and get a washing machine (proper one not a plastic twin tub) in the crew cabin.
Thing is the access is very tight. Ideally it would go into the crew cabin head compartment but the door access is only 385mm.
I don't mind taking it to bits a bit (case off etc) and I have seen this discussed.
Ive found a hotpoint which is 400mm wide (https://www.hotpoint.co.uk/h/laundr...rius-wmtf-722-h-washing-machine-white/f087755) but I dont know if there would be 15mm in the casing if it were dismantled. Also top loading might be a squeeze.
Anyone found a very very small machine for such a hole.
You mean 400mm deep, I suppose?
I also refitted the crew cabin as laundry/storage after buying the DP, and also Ms.MM wanted a 400mm deep washing machine.
So, knowing that the removal of its porthole was going to be sufficient to pass through a 390mm aperture, I bought it, in the hope that removing the door frame was going to do the trick.
In fact, eventually that allowed a further 30mm or so space in total - just perfect for bringing the thing inside, without dismantling anything from the machine.
YMMV, though: even if the crew door width was practically identical to yours, I'm sure sure that in my boat it was custom made, as all other internal doors. So, no guarantee that you will find a similar hidden space inside the frame in your boat.
Otoh, I'd be very surprised if a 385mm opening with the frame on wouldn't become at least 400mm after its removal...
2 things: yes I mean 400mm wide (see link - its tall and thin but still 600mm deep) and there is no frame on the door. its just a partition in the crew cabin, the door is over size so sits on the bulkhead, rather than in the frame. so the gap is 385mm and it isnt going to get any wider.
Ops, I didn't check the link before posting my reply, sorry.
And I actually assumed from your post ref. top loading that you didn't want it - something my wife would agree wholeheartedly...
Why not consider a 400mm deep front loading machine, then? Ours can handle up to 7Kg and 1300rpm, even if reduced in depth.
I see the point ref. the fixed opening, but as I said when I bought that model (I can ask swmbo more details if you're interested) I checked that the front porthole removal would have been a good alternative for going through the opening.
Swmbo confirmed that this is it. Her status can be checked via BT app, btw.
Obviously a solution to a first world problem, but a feature that swmbo appreciates nonetheless! :)
PS: we installed it during the 2017 refitting, and it has been regularly used since then - so far so good.
We have the same machine, very happy with it. Don’t use the dryer often but it gets things clean and has a super fast 15 minute setting. Works perfectly on a 2000w inverter if you need it to.
Can’t seem Tom find it for same outside of Italy
Even the candy website denies its existence
Sorry J, no idea of the reason, though I suspect it might be just a matter of different naming used in different markets.
I can't see why they shouldn't sell also outside IT, particularly considering that this "low depth" things seems to be a niche with not much competition...
In case NP would be unable to find out from Lagoon, if you wish to buy the thing from IT and you could use some assistance, just shout!
I just bought a slim replacement dishwasher for the boat from these guys for delivery in France. They seem to do the slim Candy machine at 360 euros - https://www.ubaldi.com/electromenag...32-47--10243272.php#p=1&pp=1&t=16&f=2939_2669
Edit: Their customer services were very helpful and responsive - my French C card is registered to my UK address, so they helped sort a bank transfer and they delivered in 48 hours
Interestingly, the model ain't exactly the same as mine: 6 rather than 7 kilos, and 1200 rather than 1300 rpm - not that it matters, just saying.
Otoh, it seems it's even slimmer, at 378mm. It could have probably saved me the hassle of removing and reinstalling the door frame.
Good find indeed, I guess it's probably perfect also for Whitelighter!
Try the Hotpoint WMTF722H check out the video on YouTube about this, see Channel 'Cruising the cut' vlog 161 Narrowboat laundry it says its 400mm width.
