Small outboard instrumentation
chris-s
24 Apr 2019
A question directed at those of us who’s sailing boats use an outboard for ‘ic’ propulsion, mine being a 6hp Tohatsu. After a recent trip which saw us motor for two 12 hour stretches, I was wondering what instrumentation would be nice to have.
So, what, if any, single instrument do you think would be nice to have on a small fourstroke outboard in this use case scenario.
Tachometer? Cylinder head temperature? Coolant temperature? Exhaust gas temperature?
Hour meter - dead simple to do if you have charging from outboard - useful for maintaining service intervals
Fuel/hr meter - much more useful, for calculating range - no idea how to do
Well it is a question OP might ponder in his boring o/b motoring journey. However best resist the thought or temptation. You do not need instrumentation and idf you do you will end up with wiring connections to a removable motor. Hour meter no your fuel consumed will be a good guide to need for service (oil change). RPM surely you can hear what it is doing. Temperature ? just look for tell tale and any sign of steam. ol'will
The more gadgets the better :). Here you go...
YAPP: DIY outboard rev counter and hour meter
I've got the source code and hardware schematic so somewhere.
The 'control box' for my honda 30 has warning lights for temp and oil. Only the temp has gone off after I mucked up the water pump whilst servicing the engine ashore. I also have an hour meter and rev counter both fed from the engine wiring loom. Rev counter is more useful as over the years I have found that keeping the engine below 3000 rpm makes quite a difference to fuel economy. I have also run the engine for around 20 hours in one stretch with no problem.
I have been told years ago by my honda engineer that the engine will run at full throttle all day, whether I could afford the fuel used is another matter.
