Greenheart
So, after literally minutes of getting the boat ready to sail (not counting three years talking about it), I discovered that the ridiculously slender mainsheet is...actually entirely suitable for the application. Not saying I won't replace it with 18mm Marlowbraid, and get blocks to suit...
...but I can see that I don't need to. One serious irritation though, is the tiny final block, which is conveniently held upright (to feed the cleat) by a powerful spring...so rigidly in fact, that it doesn't rotate readily when the swivel turns, nor when the line (coming from the boom) is sideways to the block.
So, pulling the sheet, I have to fight all the friction of the line pulling round the insides of the block, and the sheave hardly helps at all.
Is the answer to shorten the height of the spring? It's impressively resistant to squashing flat - I tried to remove the block, but couldn't.
I've only seen two sizes of spring available, the other being much bigger. I'm wary of cutting one of the doubled flat ends off the spring, lest the block leans drunkenly sideways thereafter. Is it possible to source a much shorter or flatter spring?
