Dougie_the_Mate
We have an 18 H.P. Volvo Penta 2002 on our Centaur and since we got it it has taken its time to start after a lay off of any description. The instructions we got with the boat suggested that the previous owner had the same situation. Some times it starts fairly promptly, but at others it takes several attempts.
I had got used to its eccentricities and once it is going it runs very sweetly and usually starts promptly while on passage. A friend who is fairly knowledgeable about such matter tells me whenever he sails with me that it should start better than it does.
He thinks it maybe a fuel starvation thing, but could be to do with the compression - I lean towards the latter.
Is it possible to fit glow plugs to the manifold of this particular engine to provide some pre-ignition heat - an alternative suggested solution of sticking a flaming blow torch up the air filter to provide heat is not one that am comfortable with - Mrs Dougie wll not set foot on a boat that is dependent on such a strategy even though it might well work.
Any advice welcome.
/forums/images/graemlins/confused.gif
Any advice welcome.
