slow anode corrosion
vasant
7 May 2014
Greece
Hi all,
On my volvo saildrive i replaced the anode last year as usually. Every year it was more or less decently eroded.
Now after haul out this year i saw the anode is almost like new. Almost no corrosion.
Nothing really changed since last year, boat same , marina same etc.
The ONLY think i made different this year was to use thread locker on the screws of the anode, not sure if this realy can make a difference......
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
Did you paint the saildrive with a different antifoul paint?
Thread locker will not cause a problem as there are plenty of contact points. However, you can check continuity with a multimeter just to reassure yourself.
Richard
vasant
7 May 2014
Greece
I used same antifoul. Velox.
Not sure the anode vendor was probably different
What resistance should be measured? I guess smth close to zero
neil_s
28 Oct 2002
Chichester
That happened to me with the anode on my rudder blade. I thought 'Great! don't need to do that'. Three years later there is a big, deep, corroded patch on my rudder.
vasant
7 May 2014
Greece
i only can think the metal wasnt good. Although that shouldnt happen either.
Will try again an aluminium anode as the year before and see what happens.
Neeves
20 Nov 2011
Sydney, Australia.
On another thread, and I don't recall which (but one prop AF) - i think it wa reported that application of Velox did appear to reduce anode consumption
We had a similar experience to the OP, to which I panicked, but no sign of disappearing sail drives, yet - and it might be the Velox, and I am monitoring both, or all.
Jonathan
Jonathan
