colvic987
i am getting a slightly higher oil level reading on the dipstick of my engine, it is noticed in the latter months of the season, so it is not a large influx of fluid, but a slower flow over a couple of months, the boat is in the water and used from late may through to late october, with a large amount of engine use during the summer holidays.
It is a md7a, with a msb gearbox, it had a new cone and cog fitted in 2001..
and the head was removed 3 years ago, and new sleeves and valves cleaned up by volvo agent...
I have emptied the sump and let it stand to see if there was any water in the oil, of which i cannot find, and i have read the recent thread on the head gasket failure and it does not overheat and when running it runs very well...
Is there any other area i can investigate:
1) can the shaft seals between the gearbox and crankcase cause a leakage to the engine sump.
2) can the fuel pump have a faulty diaphram and/or a faulty injector allow fuel to flow into the head and leak into the sump.
3) could the impellor pump housing seal be leaking into the block, (this i am sure is not happening as i havn't found any water in the sump).
or is there some other quirk of this engine which i have not investigated..
it is a md7a with raw water cooling which flows into the gearbox housing then into the engine block before exiting into the exhaust.
If it is diesel how would i notice it in the engine oil, would it separate from the oil like it would with water, or would the oil hold it in suspension...
1 baffled boat owner....
