Sleipner Motor Steering System Failure
J12345T
9 Dec 2009
New Zealand
Hi All,
Had an interesting situation with the steering system on my P50/3 the other day that may be of general interest. At the lower helm the steering system completely failed; suddenly, without any alarms or warnings and the manual backup did not activate. I returned to dock using engines and bow thruster.
The steering system is a Sleipner Motor electro hydraulic system installed OEM in 2008. Looking through the trouble shooting guide (not supplied with the unit) failure #7 states:-
No steering, no alarms, no backup? Stuck lock/ bypass valve.
That a critical failure like this could even happen without warning is surprising but it appears it can. The problem was a stuck lock/ bypass valve stuck in the locked position but not due to a mechanical failure. The ECU appears to have been sending a constant voltage to the solenoid to keep the valve in the locked position; thus preventing any manual reversion. Seems a new ECU will be required if it is even still available.
If you have a similar system maybe take note and know where the circuit breaker is to isolate the steering system. That will be the only way to restore manual backup..
Cheers.
