Skipper 14 Mast Mount Broken
sd4664
New Member
25 Feb 2013
Hi,
I'm a newbie to sailing and to Skipper 14 ownership, so I apologize in advance if I'm not using the correct terminology in describing the issue. I recently bought the Skipper 14, which appears to be in good condition, except for the top of the mast mount. There is a circle of (broken) white plastic, held in place by three screws, through which the mast locates to the hull. Within the hull is a length of 'pipe' (68mm diameter, approx 40cm in length) within which the mast sits. The role of the white, circular, plastic object seems to be to hold the plastic pipe and mast in place. I have (hopefully) attached some photos of these objects - my question is, does anyone know where I can find a replacement for the broken part?
Any ideas or suggestions would be much appreciated.
Steve.
