muchy_
Hi all, I want to fit a skin fitting to my boat next time she comes out but I'm not to sure of the best way to do this. I've looked at the other skin fittings and they have had wooden blocks glassed onto the inside of the hull to reinforce the skin fitting. The boat is a Seamaster 30 and the thickness of the hull is about 3/4 of an inch. The fitting will be for a toilet outlet.
Should skin fittings have this reinforcement or can I just drill a hole through the hull and bolt the fitting in with some sealant?
I'm not sure I would trust my glassing expertise if a block is needed but I would be able to do it if it's just bolted through a hole.
Advice please...
Advice please...
