Tim Good
Short version: if I accidentally made a skin fitting rotate in place by a small about whilst maintaining a valve, do I need to remove and rebed?
Long version:
Ok so I was trying to a remove a 1 1/2" gate valve for a new ball valve and in the process the whole skin fitting spun in place rather than then old gate valve. Not surprising given that it's about 18 years old.
Anyway, at the same time I tried to remove a small 3/4" seacock next to it to give access and yes it spun the skin refitting rather than the valve instead.
So in both cases, since the skin fittings was able to rotate very slightly (on a few degrees), does that mean it is now totally compromised and needs to be removed and rebedded?
Long version:
