CaptainBob
I've removed an un-used seacock with the intention of putting a blanking cap directly onto the threaded tube that comes in through my hull.
During the seacock removal, the skin fitting (brass by the way) rotate a little bit.
The sealent which previously was "glued" to the inner and outer surfaces of the hull, is now not "glued" (if you know what I mean?).
Now, on the inside of the hull is a thin nut which holds the skin fitting tight into the hull.
2 questions...
1. Do you think I need to completely remove and re-seat the skin fitting, with new sicoflex (spell?) or similar?
2. When I tighten the nut that holds the fitting in place, how do I stop the skin fitting from simply rotating in place instead of being pulled up tighter into the hull?
Does that make sense?
Thanks!
2 questions...
Thanks!
