Neil
I've had my Sadler 25 for 6 years now and each year when I take it out for antifouling, I paint over a crack between the keg and hull. I can't see any movement unless there is a bead of water in the crack and then I can see the meniscus bulge a little if I push on the skeg. It's gotten no worse over the years. I'm taking it out of the water this winter because the hull needs a good scrape before I put on more antifoul. While I was at it, I thought to do something about the crack. My thoughts were to cut a deepish 'v' groove along the crack and pack it with something. What would be better than filler? Would it be better to line the 'v' with some fibreglass mat first? I'd rather not hear about having to expose the embedded keg bolts.......
