Sizing a prop - how?
peter2407
11 Sep 2008
Long story short - last year had to have a new prop installed as the Gori folder was causing problems. Decided, under advice, to change to a fixed prop. The prop feels under powered. This is on a sail drive (SD20) with a Yanmar engine (3GM30) on a 36 ft boat of 7 ish tonnes. What size and spec prop?
You can do the calculation yourself using Propcalc on www.castlemarine.co.uk but if you are buying a propeller you should ask the supplier to recommend the size, then if it is wrong you have some comeback. Saildrive props are very predictable if you are using a standard fixed prop and a Yanmar agent will have access to suggested sizes.
Unfortunately Propcalc as hosted by Castle Marine only runs on Windows XP and Vista. I was there a few days ago and can recommend them. If all else fails I suggest you talk to them and feel certain they will advise by phone.
There is another calculator here: http://www.vicprop.com
