Miker
I've been trying to rivet a mast tang for a solid vang onto the mast. The rivets supplied are 6.4mm by 19mm for a mast thickness of 2.2mm and a tang of less than 3mm. I've had three attempts using a lazy tong rivetter and on each occasion the mandrel burst before the rivet was tight. The rivet goes into a recess on the tang, and to overcome this I put a nut between the rivet and rivetter. The job is becoming a nightmare with the hole in the mast and tang becoming bigger after having to drill out the loose rivet each time.
I've Emailed the supplier ZSpars but would welcome an independent opinion on whether the rivets the rivets are too long. All I can find on the internet is a recommendation that rivets should be twice the length of the material to be rivetted, not nearly four times.
