Siphon issue during impeller change?
motorboatdiaries
New Member
1 Jul 2016
Hi, attempting impeller change on Penta AQ205 with outdrive. Loosening the water pump cover plate bleeds water but the flow just keeps on going and intake hose remains firm which would indicate it remains full of water. I suspect it’s siphoning water up through the intake on the leg but no obvious anti-siphon valve I can see. There is a U-bend and join in the hose as it enters the engine compartment I could loosen to introduce air and break the siphon, but that seems a workaround. Question is: am I missing something obvious here, or perhaps is this an unconventional installation? Nothing on forums and websites indicate there is ever any need to release hoses when changing the impeller. Any pointers much appreciated, thanks.
This is quite normal for outdrive engines as the pump is often near or below the waterline hence inflow of water. The easiest solution is to just bend the hose to the pump upwards or bend it flat with a tie wrap for the few moments you need to pull off the old impellor and fit a new one, or stuff a bung into it.
Thanks everyone. So it looks like the answer is to play with the inlet hosing to either crack the siphon or block the end. Makes sense, but a couple of take-aways: 1) I don't think I've ever seen this referenced in any instructions, videos or forums, everything I've seen starts with addressing the faceplate and focuses on the challenges of pulling out & replacing the impeller itself, no mention of isolating the inlet feed or taking other such precautions, and 2) without taking such precautions there would appear to be a risk of significant water flow into the boat if the faceplate was removed and the water allowed to bleed continuously. I'll return later next week to finish the job, thanks again for the feedback and tips, more boating lessons learned, and no doubt many more to come...
I drive an outdrive boat occasionally and thought this problem could be dealt with by lifting the prop clear. Is this not the case?
No problem if boat is out of water!
