If you dont mind non original I believe you may be surprised that the plumbing is pretty standard. I've replaced taps and shower heads with ones from B&Q. Of course if I had told the Mrs that she'd have gone shopping in the speciality kitchen and bathroom store, but I thought the cheap B&Q ones for 20 quid looked just fine. Check the hoses under the sink, bet they are the standard 15mm plastic pipe ones with snap on fittings.
As Bruce quite correctly said, most taps can be sourced at b&q or screwfix or the like. Connections can be easily adapted. For a smaller heads basin, google mini mixer taps. These will be a better fit if room is limited as they are designed for hand basins like you would find in day an en-suite or under stairs WC.
Agree with Bruce and ST840, you can get a domestic type tap and perhaps even improve looks and/or function. I remember changing to a domestic std "tall" version for the kitchen sink on the Prestige, much easier to rotate pots and pans while rinsing them.
