Sink outlet pipe - sinking.
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
...until you notice "water pouring in and sloshing about on the bunk and floor".
He does say it USED to have a pipe.
"if it had a pipe connecting to the sink outlet it may not have needed one as it would always be above the waterline"
So no need for seacocks at all then?
Only if you break or remove the pipe. My sink outlet has no seacock & it is below the waterline. It hasn't let water in for the almost 30 years I have sailed her. Nor for the 15 years prior as far as I know.
Jaguar 25
14 Nov 2012
Liverpool
Not really, there's virtually no water pressure. Why should a decent jubilee clip give way?
There's no significant pressure on any through hull fitting but all mine, apart from the sink drain, are completed with two jubilee clips. (3 foot below the water line equates to 1.5 psi).
I wouldn't ever expect the jubilee clip to fail but it is still less likely for two to fail.
pvb
UK East Coast
Having tried to wrestle pipes off skin fittings, after removing the jubilee clips, I reckon you're not in any great danger!
Billows
31 Aug 2010
If all through hull piping were copper and glassed into the inside of the hull until well above the waterline there would be no need for all this sea cock mullarkey
Jaguar 25
14 Nov 2012
Liverpool
It would need to be well above the water line and then you would get, amongst other things, a visible heads discharge down the side of your boat.
Also, why do you say copper rather than phosphor bronze?
