Lodesman77
I have only a 105% jib but I've, so far, never felt the need to keep tension on the furling line. I'm interested in knowing what you are trying to achieve: is it to stop sail billowing out and thus harder to pull/winch in?
It depends on your setup, but if you keep tension on the furling line then it will coil neatly onto the drum without any riding turns or slack and will then work smoothly on furling. Also, if you have a larger genoa and consequently need more line, if it isn't furled tightly it may not all fit onto the drum - many people use thinner line and/or remove the core from the first section to deal with this. I have a large overlapping genoa which originally had a fairly old and thick furling line and jamming was often a problem. Thinner line and maintaining tension sorted this.
