Single plug for several intruments
Stemar
12 Sep 2001
Jissel’s instruments are mounted in a removable console (posh word for a wooden box) that fits on the companionway hatch cover when in use and are stored below in port. When the boat’s unattended for any length of time I unplug everything and take them home.
I have: Depth Transducer (coax), Log Impellor (coax), GPS antenna (coax) . At present, the wiring is through individual phono plugs for data and a cd player-type supply type socket for 12v. The Tiny Tach sensor Signal + & -, plus screen is hard wired, as a quick fix, but I need like to include it.
It’s all a bit cumbersome and awkward to connect, so I’d like to combine everything into 1 big plug if possible. In an ideal world, I’d like to include the VHF antenna, as that’s also mounted on the console, but I suspect that’s a step too far; however, the power supply is definitely a candidate. The radio’s the only bit consumer. It wants a 6 amp fuse, so I would think that there’d be an adequate safety margin if the plug could handle a sustained 6amps, with occasional peaks of 8amps.
If combined into one plug, are the various signals likely to interfere with each other?
If not, what would you suggest as a suitable plug? Might a SCART type do?
My soldering skills are limited due to lack of practice, so I'd prefer something a bit agricultural. It doesn’t need to be waterproof, because it would be fitted behind a door in the console that will keep splashes out and it’s under the spray hood, which will certainly be up if lumps of ‘oggin are flying around. A dose of ACF-50 should keep humidity at bay.
Agreed, however The BTX system is not a scart lead but is a professional broadcast connector used in the TV and stage and outside broadcast industry for connecting complex multimedia looms in inhospitible environments. Its not specifically designed for use on a boat but from the OPs description of what he's looking for ticks most of the boxes.
Thanks for the replies.
The only reason I mentioned scart is because they're cheap, have enough connectors and could be made to do the job. If they're inherently unsatisfactory, I won't bother! Out of curiosity, what'w wrong with them?
I like the ProBlox idea, but the pricing has a definite marine/medical/aviation flavour to it. I fear it's way beyond my budget.
I assume a D-sub connector (serial/VGA type) wouldn't handle the current for the power supply or VHF antenna, but could I use that or DVI to combine the other plugs into one?
One of the problems you don't appear to have grasped yet is that the GPS antenna is a coax cable carrying radio frequency currents. This will not work well if terminated in anything other than a plug/socket arrangement that is designed for RF. Such as a BNC, UHF, N or F connector. Further complications exist that the RF connector must be the correct impedance. Many are available in 50 ohm or 75 ohm versions. This is also true for VHF radio.
Your depth sounder may well get very upset if you cut the cable or change the length of the cable, even more so if you introduce an extra plug in the cable.
I'm a complete electronics numpty, so I don't grasp very much in that area. In my day A level physics barely touched AC electricity, let alone high frequency signal transmission!
In fact I do have a network coax plug/socket for the gps, thought I cant remember the type (BNC?). I cut the depth lead, and used a phono plug, keeping the length the same - I seem to have got away with that.
The thought has occurred to me that I could possibly reduce the number of connections by putting the GPS antenna inside the box, if a bit of varnished ply wouldn't attenuate the signal too much. I'd prefer not to put it on top for aethetic reasons (SWMBO oblige :))
