Desmo
Just taken my main sail off my Beneteau 323 for the first time and noticed the 4 sheave blocks fixed onto the sail (only 2 reefs) has 2 differing types of wheel. The pic shows a smaller alloy one at 36mm diameter whilst the other is nylon 60mm diameter item. All 4 block housings are the same and the sail is the original Beneteau item. All 4 sheaves were secured with a 6mm domed head screws with a thin nut of with a differing thread form and jammed on! Clearly a bodge job. The sail is in good nick and I plan to replace all 4 but would like to know:
1. Which of these were the original if either?
2. Would replacing with ball bearing versions be beneficial?
