solder monkey
New Member
Hi all,
I have several devices on-board (eg. radar, navtex etc.) that offer increased functionality with a GPS input in NMEA 0183 format. I’d like to add a GPS input to each of the devices, however to avoid a ridiculously large cluster of GPS antennae what I’d like to do is share a single GPS source signal with all the devices, ie. use one GPS antenna to feed all the devices.
Can anyone advise on the best way to do this? What I’m thinking is that it should be possible to use a GPS splitter box (powered if required to boost the signal strength) to convert a single GPS input into approximately 4 outputs.
Is this possible, and if so what’s the best way to do it?
Cheers in advance for any advice,
Mike.
Mike.
