rudolph_hart
I have one of these systems, factory fitted and driven by a Databox which is serial numbered /40 thus allowing Dataline X & Simrad IS11 displays to be mixed (which I have).
This year I replaced the Stowe speed transducer with an Airmar, which has a 'seavalve' to reduce water ingress when pulling the transducer.
It all works well, except the speed reading is quite - erm - 'optimistic', which is good for morale, but I would like it to read correctly.
I have all the relevant manuals (generously PDF-ed by other forumites), and the Fault Finding sections recommend "Calibrate the Speed Transducer (using another instrument)". Neither the SDX head, nor any of the other display heads (Wind, Nav & Central) has log speed calibration facilities in its Menu. /forums/images/graemlins/confused.gif
Has anyone successfully carried out a speed recalibration? Does it have to be performed inside the Databox itself, and if so, how?
All advice gratefully received.
