simple NMEA2000 questions from an NMEA numpty
Fascadale
15 Jan 2007
One end of the A1
Hi
Is there any difference between NMEA2000 "Backbone cable" or "Drop cable"? Are the two interchangeable?
Can I use one brand (Garmin) of NMEA2000 cable on another brand backbone (BandG)
If my speed/depth transducer is more than 6m from the rest of the kit do I need to run backbone cable to a T piece then a short "drop cable" to the transducer?
And finally, is there a simple guide to NMEA installation easily available?
For most yacht purposes, yes. There are thicker cables available for carrying more power on a large backbone, but that's only likely to be needed on very substantial systems and/or large boats with long wiring runs.
If the plugs match, yes.
According to the standard, yes. Though I suspect the world won't end if you sneak a little more onto one drop of a small network.
