We see boats lined up in marinas with spinnaker poles lashed down on deck ... along rails etc.
Now my question is .... given that a boat I had previous had a spruce boom .... about 12cm deep, less than 10cm wide .... and the spinny pole I had on same boat was about 8cm diameter ... (Alacrity 19) ... means the spinny pole of hardwood was near as strong - maybe stronger than the mainsail boom. Surely an overkill ... but it was sized correct by rigging table.
Is it really that necessary to have such strong poles for spinny's / genny poling out ? It has been known on many occasions when I was racing my 1/4T job in Tallinn - that we would forego the pole and use a boat-hook !! quick, easier - made the arms ache though !! but made fast change on short legs much better ...
Now what would be minimum size timber ? Alloy tube ? to create a spinny pole for a 25ft boat like mine ... similar sail-area to a Centaur / Colvic 26 ..... given that I do not plan to use a pole in bad weather !! and limited downhaul / uphaul fittings ....
My guess is the same or even slightly less than the pole I had on the above boat ... length of course to suit J.
