Resolution
I have been trying to purchase some Sika 292 from a well-known online chandlery, in order to stick my keel back on (sort of....)
Twice now, the chandlery has sent me a tube of Sika 291, each time with their own stock label stating Sika 292 and covering the tube's 291 lettering. If I had not removed the label on the first tube in order to read the instructions I might not have noticed the difference.
And there are two big differences: 292 has a tensile strength of 4N/mm2, whereas 291 has only 1.8N/mm2. And 292 costs about three times as much as 291.
The fact that they have done this on more than one tube suggests that there may be a whole batch that has been mis-labelled.
So if you have recently purchased any "Sika 292" online and used it in a high tension location, do go and check the labels again in case you have been sold the weaker 291.
